« Back to all recent discussions
Ethernet connection between nodes
MozMoz Posts: 1  Junior Member
edited March 2018 in Ideas
Folks, can you confirm that this is now possible?
#MultyX_March
  • Zyxel_StevenZyxel_Steven Posts: 247  Zyxel Moderator
    Thanks for your feature request in Multy X.
    The Ethernet backhaul now is not supported yet.
    But the feature is already added in our further support plan, and the schedule is estimated yet.
  • W1zard1W1zard1 Posts: 5  Junior Member
    edited May 2018
    Dear Zyxel Support,
    can you provide a timeline when the Feature will be implemented ? For me is this feature very important.
    Thanks and regards
    W1z
    It's glad to get your attention.
    We have plan to support Ethernet backhaul in the future, but the feature is not ready for now. We are still working on it.
  • fuigofuigo Posts: 3  Junior Member
    Ethernet backhaul would be an amazing feature to have on Multy X.
  • RogerRoger Posts: 2  Junior Member
    Any timeline update on ethernet backhaul?  This is awaited by many.    Thanks.
  • HanamichiHanamichi Posts: 125  Warrior Member
    May I know why you need Ethernet backhaul on WiFi System ("Tri-Band" router)?
    Do you encountered the problem? Can you share the purpose?
    To my knowledge, if WiFi System (Tri-Band router) use Ethernet backhaul, it just like general AP and will waste one band (5GHz 4x4 dedicated backhaul).
    Internet---1st node---<LAN>---2nd node, By the way, if 2nd node is too far from 1st node, the distance between two nodes may not cover each other. Your wireless devices may not enjoy whole coverage.
  • nonsnons Posts: 1  Junior Member
    Is there any news on when this Ethernet backhaul function will be available? Will it be implemented in the next firmware update?
    Hello Support,  can you provide new Infos About this feature?  timeline ?
Sign In or Register to comment.
