« Back to all recent discussions
Anybody Use Zyxel Switches?
alexriderralexriderr Posts: 1
edited July 27 in Discussions
I'm in the process of upgrading my home network and have been looking at getting some sort of managed switch (just using standard home routers at the moment).
In my search I found these Zyxel switches and was wondering if anybody here has used them before and what they thought of them. They seem to tick all the boxes of what I'm looking for (fanless, compact, plenty of port options, and managed).
  • TiggerLASTiggerLAS Posts: 17  Junior Member
    I guess it would depend on what features,
    and what level of management that you need.
    If you're looking for Layer 3 switching, advanced or granular control
    of security features, broadcast filtering, etc., then Cisco is the way to go.
    I've never seen a network switch with so many options as Cisco.  ;-)
    However, if you're just looking for something that is VLAN capable,
    then one of the managed Zyxel switches should work well for you,
    and are much more affordable.
    I use a Zyxel GS1900-8HP at home, and it has been working well for several months.
    It is fan-less, and handles multiple VLANS with ease.
  • ulrichneilsonulrichneilson Posts: 1
    edited September 18
    Hello mate, I am usingZyxel GS1900-8HP in my home, btw it's working fine from more than 8 months vpn deals black friday, let me know what issue do you have?
Sign In or Register to comment.
