« Back to all recent discussions
No signal detected on node 2 during “Location check” - what to do?
TCordthTCordth Posts: 1
edited February 17 in Questions
I have installed node 1 of a Zyxel Multy U succesfully. When I add node 2 i get the following issue. I get all the way to the step where node 1 and 2 are synced, but when i get to the “Check location” step it never detects a signal and i am not able to finish the installation. I have tried with factory reset but I always get stucked in
this step. I have also tried to move the two nodes close to each other without any luck. Have any of you experienced this problem and what is the solution?
#MultyU_Feb_2020
Answers
  • PeterKPeterK Posts: 25  Junior Member
    Have you tried to switch the primary Multy and second Multy?
    You can install the second Multy as the Primary Multy, then add the other Multy.
Sign In or Register to comment.
