« Back to all recent discussions
Expanding volume after hard disks upgrade
badkernelbadkernel Posts: 5  Junior Member
edited December 2019 in Questions
Hello
I've recently replaced all 4 disks from 1TB to 4TB and rebuild RAID5 (replacing one disk at the time).
It took 5 days to do this and had to do multiple retries to get it done (for some reason it would fail and I had to restart NAS to finish rebuilding RAID5). In the end it worked out fine.
Now I'm trying to expand volume but its not completing and status look like this:
it seems to be working on it but it eventually fails with out providing details :(
cat /proc/mdstat shows this
~ # cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]
md2 : active raid5 sda3[7] sdd3[4] sdc3[5] sdb3[6]
      11708660736 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid1 sda2[7] sdd2[4] sdc2[5] sdb2[6]
      1998784 blocks super 1.2 [4/4] [UUUU]
md0 : active raid1 sda1[7] sdd1[4] sdc1[5] sdb1[6]
      1997760 blocks super 1.2 [4/4] [UUUU]
unused devices: <none>
cat /proc/partitions
major minor  #blocks  name
   7        0     147456 loop0
  31        0        256 mtdblock0
  31        1        512 mtdblock1
  31        2        256 mtdblock2
  31        3      10240 mtdblock3
  31        4      10240 mtdblock4
  31        5     112640 mtdblock5
  31        6      10240 mtdblock6
  31        7     112640 mtdblock7
  31        8       6144 mtdblock8
   8        0 3907018584 sda
   8        1    1998848 sda1
   8        2    1999872 sda2
   8        3 3903017984 sda3
   8       16 3907018584 sdb
   8       17    1998848 sdb1
   8       18    1999872 sdb2
   8       19 3903017984 sdb3
   8       32 3907018584 sdc
   8       33    1998848 sdc1
   8       34    1999872 sdc2
   8       35 3903017984 sdc3
   8       48 3907018584 sdd
   8       49    1998848 sdd1
   8       50    1999872 sdd2
   8       51 3903017984 sdd3
  31        9     102424 mtdblock9
   9        0    1997760 md0
   9        1    1998784 md1
  31       10       4464 mtdblock10
   9        2 11708660736 md2
mdadm --examine /dev/sd[abcd]3
/dev/sda3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Array UUID : 0c7deebc:1fade3f4:1bde3e73:4bcee8ea
  Creation Time : Sun Jun 21 04:36:36 2015
     Raid Level : raid5
   Raid Devices : 4
 Avail Dev Size : 7805773824 (3722.08 GiB 3996.56 GB)
     Array Size : 11708660736 (11166.25 GiB 11989.67 GB)
    Data Offset : 262144 sectors
   Super Offset : 8 sectors
          State : clean
    Device UUID : 534058d0:e0b0f646:29a981ce:5791da0b
    Update Time : Wed Dec 11 19:29:26 2019
       Checksum : 682271bd - correct
         Events : 1366
         Layout : left-symmetric
     Chunk Size : 64K
   Device Role : Active device 0
   Array State : AAAA ('A' == active, '.' == missing)
/dev/sdb3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : f522056d:705545a6:8f06f374:21d3820b
       Checksum : a37981e - correct
         Events : 1366
     Chunk Size : 64K
   Device Role : Active device 1
/dev/sdc3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 98c36445:3c29e2e1:1c67c26c:cf29705a
       Checksum : 64f0c3c7 - correct
         Events : 1366
     Chunk Size : 64K
   Device Role : Active device 2
/dev/sdd3:
          Magic : a92b4efc
        Version : 1.2
    Feature Map : 0x0
     Raid Level : raid5
   Raid Devices : 4
          State : clean
    Device UUID : 014e806b:6a0740ae:172599c5:a7884f0e
       Checksum : 64204930 - correct
         Events : 1366
     Chunk Size : 64K
   Device Role : Active device 3
#NAS_Dec_2019
Best Answer
  • badkernelbadkernel Posts: 5  Junior Member
    Accepted Answer
    @Mijzelf
    My suspicion was the same and I did the following ( so that other can save some time)
    killed all processes that used /dev/md2
    lsof | grep '/i-data/0c7deebc/' -> will provide the list of all process that needed to be killed
    after that I unmounted /dev/md2 and check for errors :
    1. umount /dev/md2
    2. check if its still mounted with cmd df -h
    3. checked for error  e2fsck /dev/md2 ( and there where few to say the least)
    4. and then I resized it resize2fs /dev/md2
    5. checked for errors again e2fsck /dev/md2
    resize2fs /dev/md2
    resize2fs 1.42.12 (29-Aug-2014)
    The filesystem can be resize to 2927165184 blocks.chk_expansible=0
    Resizing the filesystem on /dev/md2 to 2927165184 (4k) blocks.
    The filesystem on /dev/md2 is now 2927165184 (4k) blocks long.
    e2fsck /dev/md2
    e2fsck 1.42.12 (29-Aug-2014)
    /dev/md2: clean, 211994/731791360 files, 612973016/2927165184 blocks
    Then I restarted NAS (reboot cmd) and voila new volume size and one happy camper
    Its safe to say that zyxel needs to work on GUI so that "normal" users can do this with out falling on linux command line and doing things the "OLD" way :)
Answers
Sign In or Register to comment.
