« Back to all recent discussions
C1100z Firmware LATAM
HI, I buy one router C1100Z but not work in CHILE, need modified VCI and VPI parameters.
How modified this parameters or download firmware for LATAM
Thank
PTTK
#SP_Aug_2019
Thank
PTTK
#SP_Aug_2019
Not sure where you bought the C1100Z?
C1100Z is a fully customized router for US ISP CenturyLink, and the WAN setting is also pre-configured for CenturyLink network.
So unfortunately, C1100Z might not workable in other ISP's network.
If you connected the DSL line but the C1100Z can't sync up, which means C1100Z doesn't fit that network.
For the firmware, it also fully controlled by CenturyLink on remote management system, user can't upgrade or downgrade by themselves.
FYI.
