« Back to all recent discussions
GS1200-8 - Management VLAN (Firmware V1.00(ABME.4)C0)
senfsossesenfsosse Posts: 1
edited March 2019 in Ideas
In firmware V1.00(ABME.4)C0 for the GS1200 switch series there is a new feature implemented:
  1. ...
  2. Management VID is VLAN 1 only.
According to the wording it seems the management VLAN is fix on VLAN 1 and this VLAN cannot be changed by the owner.
While limiting management to a single VLAN is quite desireable, it is suboptimal to limit it to VLAN 1 without the possibility to change this setting according to local needs. Actually, it is best practise to move away management from VLAN 1 (which is the default VLAN and therefore prone to unwanted traffic/attacks). Furthermore it is best practise to not use VLAN 1 at all due to security considerations.
I'd like to open a feature request to enable the administrator to individually set a management VLAN as is the case with the GS1900 series from Zyxel.
Kind regards,
Thomas
#Home_Switch_Mar_2019
Answers
  • Zyxel_StevenZyxel_Steven Posts: 247  Zyxel Moderator
    @senfsosse,
    Thanks for your feature request and welcome to ZYXEL COMMUNITY HOME FORUM!
    I have moved this post to Ideas Discussions. And we will evaluate it. :)
  • yggdrasilyggdrasil Posts: 2  Junior Member
    I'd like to second senfsosse. I recently bought a GS1200 as an extension to my GS1920 in my small-business+home setup. Not being able to use the same VLAN ID to use for my internal management network like I use everywhere else is an annoyance to say the least.
    @Zyxel_Steven Any news here?
  • MelMel Posts: 75  Warrior Member
    There has the workaround that downgraded to previous firmware version, it doesn't limit any Management VID, which means any VID can access the web interface of GS1200 series.
    @yggdrasil,
    Currently, GS1200 hasn't plan to allow to change its Management VID 1.
  • Leon1Leon1 Posts: 1
    PLEASE fix this! My management will force me to replace all Zyxel Switches because of the decreased security as the default VLAN ID 1 is the fallback VLAN for not authorized devices in our global networks. This will be terrible, as we are using a lot of them... Rolling back the firmware is no option due to possible security issues when we will be unable to apply future security patches. Can you please undo this change and allow to set the management access to a specific VLAN?
    Thank you!
    Leon
  • Zyxel_DerrickZyxel_Derrick Posts: 30  Zyxel Moderator
    edited May 21
    Hi Leon
    Thanks for your feedback
    We will enhance the feature that allow to set the management VLAN in the future release and the estimated schedule is in 2021 Q1
    Best regards,
    Zyxel_Derrick
Sign In or Register to comment.
