« Back to all recent discussions
Problem with two external HDD
vinpromvinprom Posts: 7  Junior Member
edited January 14 in Discussions
When I add two external USB hard drives (I use the rear USB ports) and I want to back up from NAS to external drive 2 via the Copy/Sync button, the external drive 2 does not appear in the USB volume drop down list, only drive 1 is visible and able to choose.
Initially, the two drives are visible in Storage Manager> External Volumes, but after a while, one disappears ...
I can not fully use 2 external USB hard drives at the same time :neutral:
#NAS_Jan_2019
  • MijzelfMijzelf Posts: 707  Heroic Warrior Member
    Is it a dual disk problem, or is the 2nd disk the problem. What if you only connect the 2nd disk?
  • BatouBatou Posts: 57  Warrior Member
    As far as I heard from, the usb stick with copy, it would only detect the latest one you plug into USB, so may need to plug in again the drive 2.
  • vinpromvinprom Posts: 7  Junior Member
    Mijzelf if i connect only one of this hard drives no have a problem...
Sign In or Register to comment.
