« Back to all recent discussions
WAH7706 wifi range
ExelyfeExelyfe Posts: 1
edited January 4 in Questions
I know that the range can vary depending on the conditions, but in optimal conditions (large open room, no blockades between the router and the unit), what will the expected wifi range then be, on the WAH7706?
Thank you in advance.
#LTE_Jan_2019
Answers
  • Zyxel_Support_CPEZyxel_Support_CPE Posts: 88  Warrior Member
    edited January 9
    Hi Exelyfe,
    The range is about 150m, it must be in a clear environment (no other AP signal, open space, no blockades etc). But I would like to let you know, the speed will be affected by signal strength, test clients etc. So speed is depending on conditions also.
Sign In or Register to comment.
