« Back to all recent discussions
How do I setup dedicated WiFi network for Video Streaming box (such as FIRE TV) on Multy X?
st_petst_pet Posts: 4  Junior Member
I would like to separate different WiFi Network for Mobile/laptop access and Video streamings (such as TV box/FIRE TV/Apple TV) on Multy X. Could you indicate how to set it up via App?
Best Answer
  • DexterDexter Posts: 37  Junior Member
    Accepted Answer
    It depends on the place of TV box, if it is too far, 5GHz may not good connection. Whatever, Multy X will automatically deliver the fastest wireless connection and the strongest signal connection for better reliability if your TV box is connected to Multy X. Hope it helps!  :)
Answers
  • ENDLESSENDLESS Posts: 39  Junior Member
    To my knowledge, Multy X is only support:
    - 2.4GHz/5GHz are the same main SSID .
    - Or 2.4GHz/5GHz are different main SSID .
    - And one guest SSID for 2.4GHz/5GHz.
    I have an Apple TV which connected to Multy X and works properly.
    Can you share why do you need the dedicated WiFi network for Video Streaming box? It sounds like you wants the VLAN feature or ...?
  • st_petst_pet Posts: 4  Junior Member
    Per my experience, faster client connecting to 5G radio is faster so that I'm wondering how to ensure my FIRE TV always connecting to 5G Radio...
Sign In or Register to comment.
