« Back to all recent discussions
LTE5366 - how to add additional accounts
AlfredoQAlfredoQ Posts: 3  Junior Member
edited October 2018 in Discussions
Account mgmt tab only allows to change predefined 'admin' account; how can I add more account ? It seems that this is needed for ftp service. Whenever I try to FTP to device , I am prompted for username and password credentials, and those that belong to 'admin' account do not work.
#LTE_Oct_2018
  • YeKKuYeKKu Posts: 81  Warrior Member
    Hi AlfredoQ,
    It’s impossible to add new account on LTE5366. May I know your applications for adding new account and using ftp service?
  • AlfredoQAlfredoQ Posts: 3  Junior Member
    I am trying to ftp to the device using both Windows Explorer or WinSCP (FTP). Access always requires a login. However, if I provide 'admin' account credentials, it does not work. Which credentials should I use then?
    thanks for your reply.
  • Zyxel_Support_CPEZyxel_Support_CPE Posts: 96  Warrior Member
    Hi AlfredoQ,
    It cannot login to FTP via admin account. Do you have any applications for this? If yes, please share to me and then we can evaluate it.
    I am confused; you said:
    1. it's not possible to add another account
    2. it cannot login to FTP via admin account
    hence, how should I login to FTP service ? Which software I am supposed to use (I could try command line ftp, filezilla, winSCP, Windows explore FTP...)
    Hi AlfredoQ,
    In order to provide you with a better assistance, we contacted you through private message to get more information, please check your message box.
Sign In or Register to comment.
